m1009 fuel leak on ip
6x6junkie
p.a.
hey guys have a m1009 fuel leak on the shaft that the throttle linkage hooks to on top of ip pump does that shaft pull out of there and easy fix ?? thankx
6x6junkie
p.a.
its the shaft that controls the fuel if this helps and an electronic device on one end and the other has the steel braket fro fuel control thanks
TGP (IL)
33
Metro East IL
Sorry, but that shaft does not just pull without disassembly of the pump.
It's time to remove and send off for a rebuild.
The input shaft seal will be next if not already leaking and diluting the engine oil when it does.
The new ULSD fuel play's a direct role in this problem as well as age.
The new rebuild will have better sealing material to handle ULSD..
That 's why Gov. or NOS pumps are not really a great bargain unless it's almost free.
It still has the out date seal material.
Just my Opinion.
TGP
Matt65
Alabama
Mine leaks as well, and continues to run great with good mpg. Some say leave it alone until starting or running gets worse. This is my plan as well.
6x6junkie
p.a.
yea i whould love to just leave it but it losses prime .when i try to start it it dont get fuel ok when it warms up ill try the ulsd compatable duck tape
Wolf.Dose
9
Boehl-Iggelheim, Germany
If the throttle shaft leaks, there are only 2 possibilities: O-Ring worn out or bearing sat worn out. If little leak, continue. Later the replacement of the IP is mandantory. Look for a good replacement allready. Now you have left some time to get a good IP. The old housing probabely is scrap sooner or later.
Wolf
mutt1966
13
Allentown, PA
It mite not be losing prime next time you park it open up the fuel cap a couple of turns if it starts better the next time it could be the fuel filter leaking or the check ball on top of the injection pump needs cleaning. Scott out
