M101 Axle Lubricant
Brent13
Colo Springs, CO
Is there fluid inside of an M101 axle? I took off both axle hub caps last night just for a little look inside. All was very clean and found a little bit of grease in there. I want to know the proper way to lubricate the axle or hubs, and keep them in good repair.
Thanks,
Brent
CGarbee
552
Raleigh, NC
The only lube in the axle should be the grease on the hub bearings. They are serviced the same as for a M37 (so you can borrow the TM from one of them if needed) as the M101 and M101A1 share the same hub assembles as the truck. You really shouldn't see any lube just by pulling the caps.
In short, you just repack the bearings with decent (or better) qaulity grease and renew the seals. Give the inside of the hub a swipe with grease to help prevent it from rusting (you just need a thin film). Zerks on the trailer for the suspension, lunette, drop leg(s), get a shot of GAA (I use surplus Mobile or Castrol EP currently in the gun).
Brent13
Colo Springs, CO
Okay, thank you for the information. What size is that first monster nut I am seeing? I don't have anything close that that size. Also, are the wheel lugnuts 1.5"? I am thinking about picking up the correct size combination wrench and cutting off the crows foot end so that I may slip a pipe over for a cheater bar. I have a 1/2" drive breaker bar, but afraid these lug nuts might be a bit too much. How are you all handling the lug nuts?
Brent
CGarbee
552
Raleigh, NC
Use a one and a half inch (1 1/2") lug nut wrench on the lug nuts. A Budd wrench or socket is the preferred route. Budd sockets that I have use a 1" drive (air wrench or breaker bar). I've also been known to use my Craftsman box wrench on them, but you'll find a correct socket less expensive... :)
The socket that you need to remove/adjust the bearing nuts is a KD 2438, SNAP-ON ANS-1905, or a HUSKY 15003 (W-3).
TM-9-2330-202-14-P is the TECHNICAL MANUAL OPERATOR'S, UNIT, DIRECT SUPPORT, AND GENERAL SUPPORT MAINTENANCE MANUAL (INCLUDING REPAIR PARTS AND SPECIAL TOOLS LIST)
I haven't checked to see if it is online here, if not, a version is located at:
http://www.tpub.com/content/misc_manuals_2/TM-9-2330-202-14-P/index.htm
The direct link to the section on hub, brakedrum, and wheel bearing maintenance for the M101/A1 series is:
http://www.tpub.com/content/misc_manuals_2/TM-9-2330-202-14-P/TM-9-2330-202-14-P0186.htm
Good luck.
Wolf.Dose
9
Boehl-Iggelheim, Germany
The older issue is of August 1962 and realy thin (56 pages). The newer issue superceds the 1962 issue and is dated August 1983, about 1" thick and includes the hydraulic overrun brake also.
Those are the issues I know about.
Wolf
