WhitePhoenix
- 1
- 8
- Pensacola, FL
So i just picked up this fairly nice M105A2 from GL, a big reason for buying it was because the hitch was modified to sit a solid 1 foot lower and it shows, it pulled level with my truck and even has a 12V harness setup, no lights but the wires are at the back ready to be attached. The normal landing gear were removed and the crank on the side was added (doesn't really work since there's a few notches with a bolt you put through it for the height). All in all, im excited that it doesn't require any modification to be pulled behind my truck!
