M105A3 jack
Pawnshop
23
Austin/Cedar Park Texas
I need another M105A3 jack, the one that stows on the fender and is used to lift or stabilize the trailer (NOT the nose wheel/landing gear). Where can I find one?
rchalmers3
30
Irmo, South Carolina
You can buy them occasionally from GL, however they usually come with a trailer attached 8).
Otherwise I would try Saturn, Memphis, White Owl and so on.
Rick
Nonotagain
41
Parkville, MD
Here's the good and bad news on the jack assembly.
The good news is that I found the NSN number for the jack, but it's not called a jack, it's a stabilizer.
It's a made by Pribbs, but good luck getting one from them.
Cage code 7J015
NSN 2590014875447
SUPPORT,RETRACTABLE,TRAILER
Quite a few of the trailers have come thru without the jack assembly on them. I would suspect that they didn't get stowed back on the fender and then lost. A few trailers at the site to remain nameless have shown the jack still pinned in the rear socket.
Hope this helps.
Pawnshop
23
Thanks! I will keep searching. I have a bad hip and that jack is perfect for lifting the tongue on my 101 trailers, they are just a bit too much for me, and downright necessary on the 105... I will. post a photo this afternoon.
M813rc
3,055
Near Austin, Texas
Here is a picture of the jack/stabilizer (the manual refers to it as both, and it is used for changing the trailer tires as well as leveling. Pretty cool!).
Thought I would go ahead and post it for Pawnshop since his trailer is parked out at my place. This is my trailer, Pawnshop's doesn't have a dented fender..
Cheers
mkcoen
381
Spring Branch, TX
I have to concur with Pawnshop on how handy they are. My 105 is stationary (has a 600 gal diesel tank in it) but I use the jack to lift my MKT. Since the landing gear on it is screwed up the jack is the only way I can get it on the pintle.
