M1070 tire chains with pics
Hummermark
31
London uk
Hi,
I fitted tire chains to my M1070 but one side of the chains there is a hook on clip that has no function to tighten and the other side of the chains, I.e. The outside of the tire has a hook and tension latch. I have four sets of chains, they are all like this I would have thought more logically there should be a hook on and tension latch both sides. Is this correct? I have checked the operators manual - it is not that helpful and only shows a picture of the tension latch on the outside of the tire.
I realise that the chains as per the manual should not go on either steering manual but I wanted to trial fit and it is the most convenient one to do it on. I presume they say this as the brake actuator is higher up on the steel axles (although I have seen pictures of M1070s in service in the snow with chains fitted to all axles).
Thanks,
Mark
Scrounger
65
Southern, Maryland
What you have are regular tire chains. That is correct to have only a tension device on one side. As you have surmised the open hook goes to the inside of the tire and the tensioner goes to the outside. The way it was explained to me some time ago was that the inside chain is set to the proper position and the outside chain is used for tightening. Yes, it does require a little trial and error to install and adjust the chains properly.
