m109a3 24vdc to 120vac box?
digitaldust
Twp Flint ,Mi ,
I am doing a rewire on my old M 109 might anyone know what to use for reusability this box will have see enclosed pictures.
Also is there a wiring number diagram that is of intimate detail of a m109 box for instance I have wire tags that read 700 701 that are 110 hot 110 neutral for an example
daytonatrbo
Tricities, TN
You could replace the generator plug on the outside with a standard civi plug and use it for "shore power" when camping or what have you.
If you have the need.
Otherwise you may as well gut the 110 system, unless you are going for authenticity. In which case I wouldn't mind seeing the wiring diagrams myself.
Clay James
Reno/NV
I got tired of the stock crap so I gutted it and installed a Blue Sea Systems marine grade panel. I'll add another when I do the 24v wiring.
Katahdin
23
Scarborough, ME
Its a 110v AC to 24v DC transformer to power the vent fan and other 24v equipment off a generator. You could charge the deuce starter batteries with it or run 24v radios, lights and etc equipment.
