M1102 Brake Lockout?
mbishop
Columbia SC
Going to recover a M1102 next week. Does anyone know if it has a brake lockout like the M101?
If so, would the same pin used for the M101 lockout fit the lockout for the M1102?
Thanks.
emmado22
147
Mid Hudson Valley NY
No, there is no provision for a lockout, but I have backed mine up alot, and never had the brakes lock up.. Seems the engineers figure that problem out with the brand/model surge brake they used.
macgyver5150
Vancouver, WA
The M1102 uses free-backing brakes.
You can also make a simple surge brake lockout by fabricating a channel to mount between the front of the surge brake housing and the mounting pin for the damper.
Pawnshop
23
Austin/Cedar Park Texas
Unless your brake system is defective you should not need it. My M101A2 trailers back fine and stop smooth without lockout pins. My home made M116A2 flatbed backs well however does not stop smooth when free to do it's own braking, I replaced the dampner and it still jerks when empty, I suspect it is too light weight.
