M116 Series Trailers
BM59_Fan
Las Vegas New Mexico
Hi all,
I obtained a flatbed Military trailer this last month for $150.00 that I discovered is a M116A1 that was once used to mount a welding generator unit. The ID plates are missing but the configuration is unmistakeable. This is not mine but this is the basic configuration http://www.pirate4x4.com/forum/atta...-tech-contest-cruiser-buildup-picture-188.jpg except the brake handles are different. I have found a connector harness and obtained two tail light assemblies and have had to change out the connector with one that fits my '73 710K Pinz trailer connector. Still trying to find a new M116A1 ID data plate for the trailer and the four bows for the trailer.
A question is how old it is and I see one major difference in the hand brake handles that may help. The currently built trailers all have brake handles that operate fore and aft and are straight, the ones on my trailer are curved and operate side to side. I "think" that it is a Vietnam period trailer as the old veteran in Wagon Mound NM that I bought it from has had it for quite a while. This younger veteran will tow it behind my Pinz!!
Any know when the brake handles changed configuration, and do any have a link to the correct age TM9-2330-202-14&P for the trailer? I will take some pics of the trailer and post them in a bit.
Mike
Las Vegas NM
Evil Dr. Porkchop
269
Colchester, VT
The curved brake handles that operate side to side would indicate that it is an original m116 trailer, not an a1 model. Early m116s would have a light receptacle between the handles for a separate light cable. Later m116s (and m116a1s) have the light cable wired to the trailer through a junction box on the drivers side frame rail. The brakes themselves are also different on the m116 vs. the m116a1. They started making m116s around the early fifties, not sure when the a1 model came out but I imagine it was around 1962 as that is when the manual was updated.
BM59_Fan
Thank You for the INFO!!!! I searched for M116 ID plates and found a vendor that has them, now I have to figure out what to stamp on it so I can put it on the street behind my Pinz! Any historical info on the M116 trailer that any might have would be very helpful infilling out the blanks on the data plate!!! Licensing and tagging this trailer will be an adventure as there is no original bill of sale from the military available.
BM59_Fan
Glassk,
Thanks for the info. This is what mine looks like, notice the brake handle configuration which is curved and operates side to side. I do not have the connector harness or top bows for mine.
glassk
Hampton, GA
I changed the axle and coupler also put a swing up wheel instead of the leg, have the bows and al in Montana has my cover right now, tan,...not pulling it with a Pinz though,..;)
johan77
limburg belgium
DSCI0044.jpghi, i have an, what apears to be an Original m116a1 trailer, i have it recently so i'm still doing some research about the (unit) markings that are still on it and about the year, wich i believe is around the '70's. can someone help me with the unit identification and abrevatations that are on the trailer? DSCI0045.jpgDSCI0046.jpg
mf5129
mocksville nc
that picture is a m101 vietnam era.they used 8 lug 16 inch wheels in the mid 80s till middle 90s.the older trailers had 6 lug wheels with split rims
mf5129
mocksville nc
thats right.i also had one that used a 6 lug hub similar to a early ford f-350.early 60s/it was a 67 turtle mountain genset trailer
BM59_Fan
Here are some pics of the trailer I bought. I was looking under the trailer and I found an stamped tab wired to the frame and hidden in a nook and cranny with an ID number of GC4011 on it. From the condition of the metal tab it is undoubtedly original, so I now know the Trailer ID number to stamp on the new ID plate I bought. On the rear of the trailer frame is the unit ident of FRC4/3 ACAV and HQ40ES? The unit is the 4th Squadron 3rd ACAV and I have yet been unable to decode HQ40ES except it is a HQ unit. The unit does not have a separate convoy light on the rear and it once had the cover for the cable connector on the left draw bar arm. The year of mfg is late 50's to early 60's and I have no clue as to what company made it. MOST likely what I have is a straight M116 OR maybe on the outside a very early M116A1 BUT identifying it as an M116 is safe. The tire/rim config help to identify its age as well as its unit ID which is pre-Vietnam.
