M126 Brakes???
Craig A Tull
Papalote TX
I am looking at some trailers (on line) that have M126 chassis under them, I was assuming by their apparent age that they would be air/hydraulic then I noticed the chassis had delivery dates it the high 2000s
I can not see any air chambers in the pictures and they look like air/hydraulic but there are not any definitive pictures, question these are marked M126, no A1 etc, would these have straight air brakes, and if so will all I need is the same bolts I use to un-cage civilian brakes??
Craig
Castle Bravo
Hundredaire Socialite
222
Arizona
As far as I know, 126s had air brakes, as well as 126A3s... A1s and A2s have hydraulic brakes. I think there are just 128A3s and 129A3s, i don't believe there are any 127A3s.
Craig A Tull
Papalote TX
Well it looks like I got one :) I can't remember ever caging a trailer with dual axles, do I need 2 or 4 cage bolts, I seem to remember only one axle having the park/emergency chambers. 15K and no brakes on a S1800 Int, should be fun, I should only have 3-4 stops to make in 125 miles
Craig A Tull
Papalote TX
Well I went to SA today to pick up my M129A4 with its delivered in 2009 chassis, totally prepared with my air brake cage bolts and to my amazement it had hydraulic brakes, made that simple enough as of course they had bled off long ago and I was in and out of there in a flash, this is fine with me as the truck I have now does not have air but is set up for vac/hyd brakes
