topo
- 231
- 43
- farmington NM
I'm can't find master cylinders for this trailer it has one for each axle . I put new shoes on the back axle and new wheel cylinders 2 inch . the trailer uses the same brake shoes ,wheel cylinders ,wheel seals , bearings, and brake drums as a 5 ton . but both master cylinders are leaking into the air pod . I can find air pod and master cylinders for the smaller trailers but I'm not sure if they will have the volume I need for the 2 inch wheel cylinders ? or would I be better making my own and using two new master cylinders from a m35 and adding new air pods ? any help or information would be helpful kenny
