- 34,012
- 1,807
- 113
- GA Mountains
Folks with tippers, got a few questions fer ya! Today after hours of intensiive labor (OK, 5 minutes maybe) I was able to light the old M59. Of course I didn't even bother trying to move it under it's own power, I was more interested in that dump bed. Pushed the clutch in, moved the dump control all the way fwd and let up the clutch. The bed went up smooth as silk. So after playing with it for a while I put it all the way up, or at least near vertical. It never stopped so I did. I shut the truck down and got a few pics. Here's my questions. I never started the truck again. I dropped the dump lever back to lower the bed and it wouldn't move. I'd say it was over centered and had more weight aft the pivot point. When these things are running, do they power down or float only? If they float only, I need to build a stop of some sorts. I had to swing the crane around to give it a little push. Secondly, is there a stop at all on the hydraulics when raising it? Check out the pics, it was nearly vertical. Thanks in advance.
