M35 REO Gaskets!!! PLease Help
M35 REO
Illinois
I am cleaning up my engine (M35, REO Gold Comet) and every thing i take off such as the air compressor, carborator, and exaust manifold, has ratty gaskets. i was curious as to where i may obtain a gasket set if one exists or if i have to make my own and any part numbers one might know (i had heard something about NAPA having a kit but i have not found it. any and all suggestions would be greatly appreciated.
54reo
49
Chester IL
What part of Illinois are you from?
Nice truck, not too many gassers left.
JT will do you right on the gasket set BTW...
JasonS
139
Eastern SD
I don't have the part numbers at hand but lots of the gaskets can be had from NAPA. I had the best luck making my own oil pan and valve cover gaskets from silicone sheet. Cheapest price were from "rubberman" on ebay.
hndrsonj
Senior Chief/Moderator
363
Cheyenne, WY
Well, I left NAPA today and they were clueless!. NO REO PARTS!
hndrsonj
363
Cheyenne, WY
I had the part number from a post in 05 or 06. They said it's obsolete and don't carry it anymore.
intake and exhaust valve lock 216-5146
oem type intake valve seal 216-1010
perfect circle set (requires VST-20A14 tool) *VS-6
intake and exhaust valve guide 217-3895
intake valve seat 218-8753
exhaust valve seat 218-3707
cam gear 8-3600A
crank gear 8-3601A
matched gear set 8-3602SA
full gasket set FS3146
head set HS3146
manifold set (with exhaust heated intake) MS18469
manifold set (later model) MS12199
valve cover VS39741 (the one I got was too long)
head gasket 3146
oil pan OS30987
early rod bearings 1740CP
late rod bearings 3090CP
straight shell main set 757M
Cam set 1114M
JasonS
139
Eastern SD
