m35 ujoint help anyone???
Lee Alessi
Denham Springs/Louisiana
can anyone tell me if 5704135 2920-00-075-0335 is the correct p/n for the inside snap ring ujoint for the drive shaft from the front-rear axle to the transfer case??? amazingly mine have deteriorated VERY rapidly in the last two weeks
Lee Alessi
spicer gear crawled under his and the driveshaft from the transfer to front rear (front duals) has the bolt on caps. anyone else???
if so, anyone have a spare one they will sell?
mine are so bad (i ordered the saturn ones... i hope they work) it sounds like someone hitting the bed with a BIG ball-peen hammer when you put it in gear and let off the clutch
da_sgt
Rifle, Colorado
I hope as you were leaving that "shop" you had your driveshaft over your shoulder.....and turned to say see ya....but accidentally beaned him in the head with it :boxer: Thousand Bucks :freaked:
MVtrucker
Bridgeton, NJ
My U-joints have caps (4), each held in place by two bolts. Same as the take out front shaft laying out there. I'd take a pic for you, but it's raining like crazy.
Trango
23
Boulder, CO
yep, front is external e-clips (1410, I believe), but the Trans-Tcase is bolted caps, same as Tcase-FrontTandem. Dunno about interaxle, but I think it's e-clips like the front.
Bob
spicergear
26
Millerstown, PA
All I've seen so far are bolted caps on the tranny to T-case jackshaft, bolted caps t-case to 1st position rear axle, outside snapring 1410's rear jackshaft and front driveshaft.
