SturmTyger380
- 31
- 28
- Easley SC
A friend of mine bought a sealed NOS Signal Stat turn signal unit during the Huntsville MVPA convention.
Now it is my job to install it and get it to work. This unit was in amazing shape due to it being sealed up.
I have installed it according to the diagram. The problem to me seems to be the flasher module but I am looking for any input I can to help solve the problem
When you have the power on and move the signal stat handle up or down the relays all work like they should. But the turn lights stay on and do not flash. The bulb on the stalk does not light up either and I have checked the bulb with the Ohm meter. I have also tried to ground the handle unit but that has not seemed to help.
So does anyone know if the problem would be in the flasher unit?
What is the brown thing under the flasher unit, a way to connect wires or is it a resistor?
I took the flasher off and put 24 volts to it and it stayed at a sold 24 volts but I am not sure how to test this flasher unit. It only has resistance when I put my meter on the most sensitive setting.
Can anyone help?
Can anyone help?
