bowtieman55
- 0
- 0
- Elizabeth City, NC
I think I mostly only need the lunette, anyway.The whole assembly is different, however the lunette, shock absorber, and master cylinder are the same. The landing leg is different and will not work without some modification.
They share the same part number: 10632. So you can just take it out of an m101a2 and install it in your m416a1.Gotcha. Thanks so much for your insight. On another note; if you feel that the lunette WILL work, I can get the whole surge brake/hitch setup for much cheaper than a lunette online.
