M871a2 pulled with civilian semi?
fasttruck
632
Mesa, AZ
I have one here that has 12 volt lights with a 24v plug & resistors to knock it down. Brakes and fifty wheel pin are same as commercial. I
do not klnow if all of them are 12-24v compatible as there are differences depending on what contract it is. Some have container pin locks
built into the floor and some don't. Same same lifting points etc. Trailer is 28' long and has s cam straight air brakes with anchorlock 30-30
chambers.
fuzzytoaster
3,033
Fort Worth, Texas
Yes, most of semi trailers have the 12v/24v lighting. Inside my M871 all the lights are 12v with a resistor step down on the 24v plug.
Scottgeneral
Destin Florida
This is the trailer I purchased. I am asking these questions because I need to have it transported. I wasn't sure if it could be pulled by a civilian semi or transported on a trailer.
thanks for the input
Trailboss
137
Norwood LA
If you look close at the photos of your trailer, you'll see the blue "service" glad hand is broken off (a lot of these trailers have one broken off due to lazy drivers), meaning the trailer will have no brakes. It can be towed, but not safely until the glad hand is repaired.
Otherwise, it does have both the civilian and military light plug sockets and can be towed by either tractor.
