M920 tach cable issue, wiring, throttle linkage springs, picture request
Thomas_G
Houston, TX
Hello.
so I took over installing the fuel pump (new). Well the new tach cable 6680-01-082-6802 the pump end cable side is incorrect size. Anyone have a idea where I can get one.
Also anyone have pictures of the throttle spring set up and wiring to the shut off solenoid and 10 psi switch.
Thomas_G
Houston, TX
That’s what I needed. I am missing that bracket for the spring. Is there another spring on the rear of throttle linkage? A diagram I found shows one
WillWagner
2,606
Monrovia, Ca.
There are two sizes of tach drives, The small one is the most common, the large one is what is used on the military pumps. Take the new and old pump to a pump shop and they can swap them
WillWagner
2,606
Monrovia, Ca.
Dealer will want a VIN, they can't do anything without it. What is broken, the cable?
155mm
Chief and Indian
387
Guymon, OK
I called our parts house here, he said 6’ tach cable with big collar for big cam 3 is about $120. I will get hard measurements tonight and verify they are the same
