M925 Filter cross reference
Bighurt
46
Minot, ND
I tried seaching to no avail.
Does anyone have a list of NAPA part numbers for the NHC 250 used on an M925. I know I'll need fuel filters, hopefully the same as the 400 cause I have a box.
But I'd like to get a full set of filters for the recovery, to include air if necessary.
If there is already a list, I'll delete this thread.
Jeremy
R Racing
St. Leonard, MD
Its not Jeremy the ntc 400 uses a smaller can filter . the M809 series NTC250 uses a cartridge .
Fuel filter is NAPA 3401 I also ha a Baldwin # PF 316
Bighurt
46
Minot, ND
Cool looks like someone needs to do a spin on conversion...
Now I just need to find oil and coolant, I suppose those are cartridge as well.
Thanks for the response.
Bighurt
46
Minot, ND
Alright Baldwin has an awesome site...
Oil Filter Primary P999-HD or spin on B196*
Oil Filter Bypass spin on B7577**
Fuel Spin on BF957 or BF1212 can be used for fuel/water separator
Air PA643
Coolant BW5071
*To convert to spin-on use OB1368 or OB1369 base and B96. CAUTION: When converting from bag-type with any conversion kit, lines must be switched so oil flows outside-in
**To convert to spin-on, use OB1308 and B7577
I also should add those numbers were given by engine model not make so some discrepancies may exist between civilian and military applications. Perfect example is the fuel spin, may not apply to any military version as it's been noted by R Racing that it's a canister type filter on M809 and M939 series trucks.
EDIT; Corrected numbers originally posted NTC 250 vs NHC 250 filters.
Bighurt
46
Minot, ND
Updated list
NomenclatureNSNPart #Company NumberContactNotes
Air Filter294000134465711604545Cummins8123775009Duscan M. JanicNo Cross
Air Filter2940001344657P10-8874Donaldson Company Inc9528873227Robyn BarlageCancelled
Air Filter2940001344657P52-9263Donaldson Company Inc9528873227Robyn BarlageNo Cross
Air Filter Kit2940011079689KYX00-5642Donaldson Company Inc9528873227Robyn Barlage
Air Filter Kit2940011079689GMW250C92KITBGreenlees Manufacturing Inc7732874136Lorie Greenlees
Fuel Filter Kit2910001522033FIL 3401NAPA7706618664Jim Weaver
Fuel Pump Filter2910007908736BM28850Cummins8123775009Duscan M. JanicNot Available
Transmission Overhaul Kit25200114023766884259Allison3178215233Pat Young
Transmission Filter25200121167026882787Allison3178215233Pat Young
Transmission Filter2520012116702FIL 1892NAPA7706618664Jim Weaver
Hydraulic Filter2940011102489FIL 1268NAPA7706618664Jim Weaver
Power Steering Filter2530011375921ERS-27785Eaton Corp2697818301
Oil Filter2940000733316FIL 1954NAPA7706618664Jim Weaver
Here is an updated list.
Please note the info is achieved by looking up the part in the -24p. Then I ran the part number through webflis to get an NSN, referencing the cage code from the -24p I was able to provide the company info. The info above is company number and the agent in charge as identified through DLA. This is public knowledge and not subject to privacy act compliance, this is not personal identifiable information.
For example I was able to contact Robyn Barlage at Donaldson and find out the air filter is available and there is a military supplier in MS that has 117 on hand. Not sure if they are NOS or NEW, but they are available, no word back on cost.
Hope this helps.
