Sknttu
- 0
- 1
- Amarillo, tx
I have a 92 934A2 that has me at a loss. I have scoured the active threads and can’t find anything that has helped so if you have an idea, I appreciate your input.
The issue:
I recently went to drive the truck. Started it up turned lights on and noticed I had no brake lights when I pushed the pedal. I next tried the turn signals and no front or rear lights for them either. In retrospect, I remembered smelling something “electrical”. I have a second truck. 923A2 and I tried changing the turn signal activator and no changes. I then went through the TM’s on trouble shooting this and they pointed to bad flasher. Order one in, plug it in and...nothing. Try that flasher on the working 923 and it doesn’t work. Thinking is was bad, I return it and they send me another. Plug the new one in and this time I hear a pop and the potting on the back looks grey on the inside, like it’s burned. I try it on the working truck and it did not work. I started trying to discover a short. I made a small jumper to go from the input wire on the flasher plug to the output wire. I moved the turn signal to the left and the front and rear signal lights work, to the right and they work as well. I never had sparks and never had a hot jumper wire either and no continuity with a ground. Next, one thread recommended the Grote flasher, I ordered 2 to be safe. Before I plugged it in, I went back through the TM for the flasher and compared to working truck and all is well. I noticed that I have 24v coming to flasher from turn signal when it is activated but then I found when it is turned to the right I also have 12 volts to the output wire side. This is 12 with no flasher connected to the wire that runs back to the turn signal unit to go to the lights. The 12v was at front and rear lights as well. I disconnect the harness and test all the leads to the turn signal and none have 12v. I try with the working truck’s turn signal on the 934 and I have the same issue: 12v coming from output wire with no flasher attached. The 934 turn signal unit works fine on the 923. I install the Grote flasher to try it and nothing happens. Put the same Grote on the 923 and it works perfectly.
I’ve checked my grounds that I can find. The only thing I haven’t tried is the brake light switch and the 3 way service light switch. It works for headlights and tail lights and dash lights in appropriate positions.
PLEASE HELP BEFORE I FIX IT WITH A MATCH AND A CAN OF GAS!!!
Steve
The issue:
Steve
