M939 No air pressure build up
Thomas_G
Houston, TX
Have seen several posts on this subject on not building air, I have a M939 that i removed the air discharge line from compressor (brass line) and could feel air pushing out of compressor (rules out bad compressor), installed new air governor and truck will not build air at all. Possible that the air dryer filter is bad?
simp5782
Feo, Fuerte y Formal
9,339
Mason, TN
Grab the line coming off the drivers side frame rail into the dryer. is it vibrating or clicking? means its building air to there if it is. Then just pop the drain ports on the side to see if you have air there? If you got the click into the dryer and no air on the drains then you know. The dryer if you have not changed it before could be stopped up. Just take it apart and clean it. It's not to difficult. The rebuild kits are available from Napa and Truck Pro pretty readily.
gimpyrobb
dumpsterlandingfromorbit!
27,785
749
Cincy Ohio
Is it a tractor? 939 covers a BUNCH of trucks. I recovered a tractor once that had the valve for the trailer opened. Talk about a "face palm".
Thomas_G
Houston, TX
This is a cargo truck, and i am pretty sure the air dryer has not been serviced, i did crack the air bleeds on passenger side, very little air came out, this was just released from service and is now owned by a museum. I found a rebuild kit for under 150.00 and will try that
M35A2-AZ
390
Tonopah, AZ
Is air leaking out the bottom of the air dryer? If so just push up on the center of that is in side and it should stop.
Suprman
684
Stratford/Connecticut
Take the air line going into the dryer off see if air pressure. If so take the air line off the air dryer out see if pressure.
sandcobra164
288
Leesburg, GA
If you are considering a rebuild kit, might as well just purchase a brand new one. Member Suprman has some that fit just fine and depending on shipping costs, might be cheaper than the $150 price of the rebuild kit. I have one on my cargo truck now and it works great.
Jbulach
2,134
Sunman Indiana
Make sure your glad hand valves are closed front and back.
You say you "could feel air pushing out of compressor"... I'm not sure this rules out the compressor, unless you actually put a gauge on it? Moving air doesn't necessarily = pressure.
Be careful if you check this without a tank or relief valve though. Maybe just crank the motor over while someone else watches the gauge...
Csm Davis
382
Hattiesburg, Mississippi
Ok has the truck ever had pressure? Have you closed all 3 glad hands? Most likely culprit is valve on bottom of air drier, won't hurt to remove it and clean it, then put it back in.
sent from my decrepit fingers
gimpyrobb
27,785
749
Cincy Ohio
You can put shop air to the front glad hand to see if the system will hold air. You might even be able to hear where its leaking if not!
Thomas_G
Houston, TX
I removed the purge valve and cleaned up the bore, it was pretty tight with very little debris, I resealed and going to put on this weekend, hopefully that may of been the problem. I was told it would air up before, the desiccate filter was like new.
