74M35A2
- 318
- 83
- Livonia, MI
Fuel gauge is way off. Disassembled sender, found copper float chamber full of fuel. Replaced with new sender. New sender now ohm's out OK, but gauge still reading off scale. 24-28V power into gauge checks OK, but ground circuit resistance on wire to sender shows 30 ohms. After checking, ground resistance from battery "-" to any body ground show 30 ohms. Since the gauge works in the range of 0-30 ohms from the sender, adding the 30 ohms body resistance will put the gauge off scale the entire time.
Also noticed when a sudden electrical load is activated, the oil pressure gauge needle will change positions simultaneously. This is also indicative of a bad ground (?). The differential ground resistance increases as electrical load is applied (between battery bank "-" and any body or frame measurement point, so I am thinking a bad ground for sure.
Ground resistance as measured from battery bank to back of starter ("-") measures nearly 0 ohm's, so this is OK. There should be a firm ground connection either from the starter ground to the vehicle body/frame (these starters are not grounded through their frame metal like automotive are), or from the battery bank "-" to a body/frame ground. I see a heavy ground cable coming off the starter and going to a bulk harness, but I have not crawled completely under in an attempt to chase it. It is 0F here in MI right now, so I am hoping I can cheat and have somebody tell me where the frame/body ground connection point(s) are, rather than lay on cold concrete @ 0F and try to trace it. I could not easily find it in the TM's, albeit I need to become more fluent in those also.
Thanks in advance.
Thanks in advance.
