Csm Davis
- 376
- 83
- Hattiesburg, Mississippi
M939 Transfercase shifting and front axle engagement
The Transfercase shift linkage has a bad weak link and in my opinion a unneeded locking mechanism. Both of these combine to make for a hard shifting tc.
First the weak link is the flat stock piece at the tc pto it flexes and bends I am looking at adding some reinforcement to mine.
Second problem is the air lockout on the tc I do not believe it is needed. If you will try to shift your tc without the truck on and no air pressure you will find that it probably shifts much easier, and unlike the 809 series trucks this tc lever is not likely to get knocked out of gear.
