M939a2 CTIS wheel valve not closing due to air restriction in hub.
Jbulach
2,134
Sunman Indiana
I have a slight air restriction in the left intermediate hub, somewhere between the wheel valve adapter, and hose fitting on the back side of the hub. This is causing the wheel valve to hang open and dump air until the tire pressure drops to around 55PSI, then it closes.
Anyone have any experience or ideas what could be causing the restriction through the hub?
Jbulach
2,134
Sunman Indiana
Yep, old and two different NOS valves all act the same +/-5 psi.
Jbulach
2,134
Sunman Indiana
Maybe the quick release valve on the axle is clogged up
I’ve eliminated the QR valve and the hose to the hub, by disconnecting the hose from the brake backing plate while wheel valve is dumping air, still no change...
