Mack Motor Demand
tie6044
42
Blaine, MN
Is there much of a demand for Mack engines? I have done a lot of reading on the older 5 tons and from what I have learned they are a very desirable motor but there are not a lot out there. The reason I ask is I found an M54A1C that is in VERY rough condition outside from being used in the woods and the t-case is broke but it runs good and I want the axles. The frame has been cut and it would take way too much to save this one. The motor and tranny I don't have a use for (unless I can stuff them in a deuce:)) and I was wondering if there is any demand for a good takeout motor or if I will sit on it for years. Sorry, no pics unless I buy it and get it home.
fasttruck
622
Mesa, AZ
it will only fit in a 5 ton and in addition to the motor and the trans you will need several of the harnesses, the throttle linkage, power steering lines etc as almost everything that attaches to the engine is in a different place compared to a continental in a a2.
AMGeneral
92
Connelly Springs, NC
I'll be glad to take it off your hands,I need another spare engine for my 3 Mack powered trucks.
fasttruck is correct though,just about everything is specific to the Mack powered truck,harness,throttle linkage,radiator,primary fuel filter housing/filter, exhaust "J" pipe,even the alternator/genarator pulley is Mack specific.
Heck even the throttle/engine stop cables are specific to the Mack powered trucks.
tie6044
42
Blaine, MN
Wow, I guess I thought there would be more similarities to the deuces or other 5 tons. Oh well, I think I might get it and hope for a buyer for the motor and t-case after I get the axles out.
73m819
314
gainesville, ga.
I would get it, get the axles, springs, mounts, what ever ealse you need, cut the front off, drop the xcase, keep the drivelines, scrap the rest unless someone comes up with a need
vtdeucedriver
Vermont
fasttruck is correct though,just about everything is specific to the Mack powered truck,harness,throttle linkage,radiator,primary fuel filter housing/filter,even the alternator/genarator pulley is Mack specific.
Oh jeese
tie6044
42
Blaine, MN
I'm going to go pick it up today! I'll post some pics when I get back. One question I have (slightly off topic) is if the t-case rear output shaft is broke should the truck still drive assuming the front part is fine? I'm not driving it home, just onto my trailer.
73m819
314
gainesville, ga.
depends if the tcase is broke inside, is just the drive line to the rears is broke, all is ok, if output shaft is broke as this shaft also drives the front sprag clutch, no, if the rear output drive flange is broke or broke off only then the tcase should be ok to load
hope this help
tie6044
42
Blaine, MN
Here are a couple pics. The rear output shaft is broke but it goes backwards. Makes finding a parking spot or turning around rather interesting! Probably not a usable body panel on it but seems to run good, at least in reverse!
AMGeneral
92
WOW:shock:
Looks like the hood and engine side panels/air cleaner are salvegable,but that's about it for the body.
Got your PM,will respond soon.
Long trip,about 2,268 miles round trip from here to there
Could you make a short video of it running and post it here?
tie6044
42
Blaine, MN
I've got a lot of deuce stuff too, maybe someone on the trip might need something delivered to help cover fuel costs
