Isaac-1
- 48
- 48
- SW, Louisiana
I had to pull the fan shroud off of my MEP-003a in order to change out 2 of my diesel injectors. The two cylinders on the end closest to the blower were very slow to fire after starting on the other two (5-10 seconds), and would blow white smoke for a couple of minutes, changing out the injectors for a pair of tested used ones has helped, but they are still a little slower to fire off, but at least now the white smoke is gone after only a few seconds, in fact one of the two I did not change now puffs white more than they do. My question is what else should I check in detail (other than a quick once over) while I have the shroud off?
Ike
p.s. I plan to check valve clearance also while things are apart, and I am installing a new starter (old one is marginally weak) along with a spin on oil filter kit.
Ike
