rose1111
- 0
- 1
- California
I am having trouble with the voltage on my generator (MEP-006A Military Generator). I can only get 166 volts coming to main contactor. It needs to read at 208 volts. I have done the following to try to fix it:
1. Replaced the excitation system assembly box
2. Replaced alternator
3. Replaced relay assembly box
Nothing I have tried is working. I am not sure what could be causing the problem with voltage and I need to get it up and running asap. Are there any suggestions on this?
