MA MEP-805B, MEP-806B CIM Brightness Adjustment Tool
kloppk
889
Massachusetts
Available now are the custom cables assemblies to adjust the brightness of both the MEP-805B & MEP-806B CIM displays.
I personally build each brightness tool and test each one prior to shipment.
Usage...
Use the adjustment cable to set the contrast back to normal. To make the contrast adjustment, attach the adjustment cable to P27 connection on the CIM and connect the P31 power supply. Power the CIM up and make the contrast adjustments by repeated clicks of the toggle switch in one direction. If this does not produce a change after a few clicks try the other direction on the switch. Each click on the switch increases or decreases the contrast by a set amount depending on the direction the switch is activated.
After you have achieved the desired contrast, reinstall the repaired P27 cable.
Ordering Information
Cost: $75 Includes USPS Priority Shipping in the US & US Territories. Canada slightly more.
PayPal & Checks accepted.
To order email me at: kurtklopp@gmail.com
Be sure to include the following information:
1) Name & Mailing Address
2) Payment Method
4) PayPal email address if using PayPal
