Mfg. ?
Oasis-3
Columbia, PA
How can I find out who is the Mfg. of the trailer I just picked up at GL.
It was listed as MDL M101-A1 the data plate showes it's a 1962 but the MFG. is blank. I have the vin.# if that helps.
319
Lieutenant
58
Michigan
Need to find someone with an intact complete data plate on their 1962 M101A1. It should be the same manufacturer.
NDT
6,305
Camp Wood/LC, TX
Johnson Furnace? Post all the numbers you have and let us sleuths get to work. Should be 5 lug Budd wheel with no surge brakes to be a 1962.
Oasis-3
Columbia, PA
Thanks for the replies
Year 1962
Fed # 233-898-6779
Mfr#2359
DTID W25M6N023530A4A
NSN 2330008986779
I have a 1968 Johnson Corp. and getting a SF97 was easy for that one.
If I can get the correct name for this 1962 I will stamp it on to the data plate then I can get a good title for this one.
Thanks Again
Oasis-3
Columbia, PA
Cage Code, = 19207
Ok good Idea
NSN:2330008986779 [FONT=Verdana, Arial, Helvetica, sans-serif]Item Name:[/FONT]TRAILER,CARGO Query Type: PUBLICDate of query:12/24/2010 3:09:32 AM
M101A1 19207A515AZ3D8736397 19207A511AZ3D13212E3552 97403A521AZMILT10579 81349M41XTG3D
NAMEITEM NAMETRAILER,CARGO AAFZBODY MATERIALSTEELABHPOVERALL LENGTH147.375 INCHES NOMINALABMKOVERALL WIDTH73.500 INCHES NOMINALADJTINSIDE WIDTH66.000 INCHES NOMINALADJUINSIDE LENGTH96.000 INCHES NOMINALAFMQINSIDE HEIGHT18.000 INCHES NOMINALAJGEBODY TYPEBOX W/LATTICE SIDE EXTENSIONSALYPFLOOR LEVEL DESIGNFLATAPGFDESIGN TYPEWHEELEDATYXCAPACITY RATING0.750 TONSAWHABED TYPEFIXEDAYFNSUPPORT TYPEADJUSTABLE LEGAZBTWHEEL ARRANGEMENT STYLE2 SEMI REAR, SINGLEBPGNPARKING BRAKESINCLUDEDBPQWSUSPENSION TYPETHROUGH SHAFT AXLEBRRZTARPAULININCLUDEDBRSBTOP BOWSINCLUDEDBRSDTAILGATEINCLUDEDBXJLRETRACTABLE SUPPORT FEATUREINCLUDEDCCRWDRAWBAR TYPERIGID A-FRAMECGNWLOADING RAMPNOT INCLUDEDCGNXDISTANCE FROM BODY FRONT TO DRAWBAR COUPLER CENTER41.750 INCHES NOMINALCGPGDRAWBAR CHARACTERISTICFIXEDCGPHDRAWBAR COUPLER TYPELUNETTECGPKTOWING PINTLE HOOKNOT INCLUDEDCGPNBODY FRONT SHAPESTRAIGHTCGPPPLATFORM LOADING HEIGHT ADJUSTABILITYNONADJUSTABLEZZZTNONDEFINITIVE SPEC/STD DATAM101A1​
[FONT=Verdana, Arial, Helvetica, sans-serif][FONT=Verdana, Arial, Helvetica, sans-serif]http://www.dlis.dla.mil/webflis/pub/pub_search.aspx[/FONT][/FONT][FONT=Verdana, Arial, Helvetica, sans-serif]
[/FONT]
still looking for a name
Search by
CAGE Code: 19207
Company Name: U S ARMY TANK AUTOMOTIVE COMMAND CAGE Code: 19207 DUNS Number: JCP Cert. Number: ZIP Code: 48397 State: MI Phone:
Name:U S ARMY TANK AUTOMOTIVE COMMAND
AMSTA-IM-MM CAGE Code:19207 Status:A - Active RecordParent CAGE:Address:11 MILE RD P.O. Box:City:WARREN ZIP:48397 CAO-ADP:S2305A - HQ0337State:MI County:MACOMB Voice Phone Number:Fax Phone Number:Date CAGE Code Established:11/27/1974Last Updated:8/31/2004
[FONT=Arial,Helvetica,Univers,Zurich BT,sans-serif][SIZE=-2]Last Updated: Monday, November 17, 2008[/SIZE][/FONT]​
Company Name = US Army Tank Automotive Command
Ouch looks like a dead end aua
Good Try 4X4
jaxsof
15
Dundalk, MD
I have found a few, and all 1962s I have found were made by JETA MFG. I dont think they are related to the company with the same name in Neenah, WI
Hope it helps
Scarecrow1
Florence , S.C.
I agree with NDT your # s are close to mine and its made by Johnson corp Bellevue ,Ohio the national stock # is 2330-00-898-6779 your Fed # 233-898-6779
mine is a 1968
Wolf.Dose
9
Boehl-Iggelheim, Germany
But it might be a Case Master Body Inc. or GAr Wood Industries as well. There are many makers for these trailers.
All have 4 didget serial numbers in the 1960's.
All M101A1 have the FSN 2330-898-6779.
Refer to TM 9-2330-202-14P, August 1962.
Wolf
