Mounting 100A dual voltage
Mogman
9,211
Papalote, TX
Will the 100A dual voltage Niehoff alternator fit the aluminum 60A mount? What about the 200A mount??
The parts TM lists only one mount for above 196XXX serial number, not sure what that split is about..
Coug
4,243
Olympia/WA
Looking in the manual, the 60 and 100 use the same mounting bracket. Only difference between the aluminum and steel that I can see has to do with either using a through bolt for the alternator pivot, or using 2 separate bolts front and rear.
The 196900 split has to do with the serpentine belt system. Above that uses an extra pulley between the alternator and PS pump. Below that doesn't. Also different PS pump designs. These are A2 and newer trucks only, so all have the 200 amp alternator (unless they have the 400 amp)
I don't believe the 100 amp works with the 200 amp bracket, because the 60 and 200 use different brackets.
100 amp was only on A0/A1 trucks, so V-belt systems, not serpentine.
Mogman
9,211
Papalote, TX
So I guess there is no reason to keep it as a backup for the 200A.
It came off the DuraVee, a 1993 M998 with low miles, I thought it was a 200A by the pictures, as it turned out someone just dumped it in position when they pulled whatever alt was in there.
I did pull the regulator and tested it on my 200A, it was toast, I need to make a run into CC anyway so I will stick a good regulator on it and have my buds down at the ye ol starter/gen shop give it a spin.
When I bought GEP turbo engine for the Detroit I could have had the 200A alt and the starter for $500 more, hindsight says I am a dummy:oops:
I wonder if Neihoff has a troubleshooting guide for it, I suspect the 200A guide can be used, for the most part they identical electrically but for size/capacity
I would expect the field windings to have a little higher resistance.
  • Like
Reactions: cwc
86humv
498
Texas
The early series Serp system has a bracket for 100 and 200 dual volt....100 is different when you put one next to a 200.
Late Serp on used a 200 or 400.
Mogman
9,211
Papalote, TX
By the GP pictures all I really paid attention to was the dual voltage reg, did not think to study it closely.
