joshs1ofakindxj
- 112
- 43
- SW PA
I just can't take it anymore. The deuce has been great to me in original form, but it's time to go wild. Everybody and their brother can buy a regular deuce and drive it around. I want my own crew cab 4x4 with a M105 bed. I've been reading build threads and I have a good idea of what I'm in for. I found a cab already to attach to mine and I have the M105 suspension and trailer body.
I've been trying to talk myself into a bobber and then it hit me, I love the size of my truck and want to keep it the same length. I want a full length 4x4.
My bed is sold and will be gone in 2 weeks. I'll pick up my second cab and prep it for mock up. I'll tear down my M105 and sit the bed on the frame. At that point I'll decide where the axle goes. I've read the discussions, and I will be going with the M105 springs and frame bolted and welded to the deuce frame with heavy reinforcement. Planning on a lot of 1/2" Grade 8 bolts and 3/16 7018 rods burned in.
I plan on a soft top so I can mount a gun pedestal right in the center of the cab.
I want the largest tires I can fit without a lift. The lift might come after, but not at the same time.
One thing I have no clue about is if I need one long driveshaft or a two piece shaft with a pillow block support bearing? The rear axle will be pretty far back. Not sure how long of a shaft is possible.
Any advice for the major hurdles in front of me or pitfalls would be appreciated.
Back to reading more build threads...
