Mystery wire………
joediveguy
Front Royal, Northern VA
See the pic below, what is this connector for? Yellow wire and Purple with a white stripe. It was disconnected under the dash and looks like it should connect to the brown wire near the top of the fuse block by the 10A fuse. What do ya’ll think, should I just connect it and see what happens?
CycleJay
Marietta, Ga
Hi,
I am no expert, But I would not connect it until you find out what it is,
so you do not fry anything.
Just my $0.02 cents..
Good night
CJ
Reverend Evil
Crestview/Florida
A little more info would help. like has your truck had the 12 volt conversion done to it. To me it looks like the purple wire that goes to the starter solenoid under the dash (see doghead mod) other than that I went through the -tm and rewired my entire under dash off the schematics and I dont know jack about wiring .(do now) it is pretty self explanitory . but I am sticking with solenoid wires. Does the truck run now without starting issues?
joediveguy
My truck has not had a 12V conversion. However, the PO did make his “own” modifications that I am going through and fixing now. Here is the link to it’s story:
http://www.steelsoldiers.com/showthread.php?t=78159&referrerid=33516
“To me it looks like the purple wire that goes to the starter solenoid under the dash”
“Does the truck run now without starting issues?”
- Starter solenoid has a solid purple wire. This has a Purple with a white stripe.
- No starting issues now
1,168
I just looked at my truck, and I can't find either of the wire/plugs in your pics!
Are you referring to a one wire(brown) connector and the 2 wire connector, and thinking they go together? Kinda confused.
The schematics are in the back of the -20 and -34 TMs.
1,168
I found the single wire(brn/white) wire. It goes on the parking brake switch. It's way up above and behind the silver round relay in the top left corner of the fuse panel(on the P brake mechanism)
Still not seeing the other 2 wire connector.
CycleJay
Marietta, Ga
Joe,
I have an M1009, I will check under my dash when I get out there today,
and have a look for you, and will let you know what I find out.
Good day,
CJ
dstang97
30
Clover, SC
I will check that out….
But I would feel more comfortable if somebody with a CUCV could take a look under their dash for me and see if these two are connected.
I do indeed have cucv's and looked. Looks like so far I am 1 out of 2 correct.
1,168
Yup, but for the other, the colors and number of wires, does not match the schematic or my truck.
dstang97
30
Clover, SC
Ok now I am getting a little confused. Now that I think about it Isn't the back up lights a blue and a green. It was at least 2 years ago when I messed with my blazer and i remembering different wires than My 08. Anywho the wires yellow and purple with white tracer are hooked up at the bottom of the steering column. Like I said it was 2 years ago and i believe that is the back up light switch. Another thing Im thinking both of my 08's were built in 83, so they could have made an upgrade or something. even though they are supposed to be the same.
joediveguy
Sorry for the confusion dstang97, I was asking if those two connectors should be connected “together”. 2 wires, Yellow & Purple with a white stripe into the one Brown connector. Doghead’s reply on the brown wire makes sense as the paring break is unconnected and the break light is on so I bet the brown one does go to the switch. I have not had enough coffee yet to unass the computer chair and go look.
dstang97
30
Clover, SC
Gotcha. On your B-piller there is a data plate what year do you have?
joediveguy
Okay, just took a peek and found that connector, but I can’t get my fat fingers up there. Time to get into my work clothes and dig in. Thanks Doghead. Now find that other connector for me![thumbzup]
1,168
I guess, if everything works with it unplugged, them leave it alone!
