m35a2cowner
- 2
- 16
- Columbus, Ohio
In my fervor to finish my front end work on the deuce I forgot to lube the front axle bushing in the inside end of the stub hub (actual term?) when I put it over the axle. The cavity is packed with plenty of NAPA's finest grease that crossed over with the specification in the Lube order. Is this a sin worthy of dis-assembly (Its not yet all the way together yet) and correction or will grease make it in there before any undue wear happens? Thanks
