Need help to identify a trailer
combat32
106
Booneville AR.
It is obviously early WWII, still has the marble reflectors, I first thought it was a Ben Hur but it is smaller, data plate says G 516, never heard of one and can't find any info online.
maddawg308
747
Front Royal, VA
According to the internet, the G-516 series of trailer is
G516 Trailer 1-ton, Miller Model CP-1.
Some pics would help....
maddawg308
747
Front Royal, VA
You might try over at G503 site, those guys have WWII field drab in their bloodstream, might be able to help you out with the older stuff more than we can....
MWMULES
345
DESOTO, KANSAS
What is printed on the data plate? It sure looks like a 1 ton, but like some on here are doing with the M101 and M105 trailers have changed the axle to make it lower to the ground. With the marble reflectors could be prewar , "1Ton Quartermaster trailer" which is what the G516 was based on .
combat32
106
Booneville AR.
Its dark now, will post up a pic of the data plate tomorrow.Everything underneath looks correct, if they swapped axles they sure did a bang up job as the e brake cable is hooked up and it sure seems to look original except the wheels.I can't seem to find any pics of one anywhere.
Also you can see the original U.S.Army and reg number painted in blue then overpainted later in white, I think that makes it pretty early.
Bumper numbers are AAATC 217 AAA C17 Wonder if Carnac could look those up:mrgreen:
Previous owner has had the trailer since 1946, he bought it from the man who bought it surplus off of Ft. Chaffee, said it was like new when he got it.
NDT
6,305
Camp Wood/LC, TX
It's a WWII 1-ton for sure, just has the 6 hole Budd axle and 7.50-20's swapped out with the civi axle. That trailer looks like it would restore nicely, just a little cancer in the front.
combat32
106
Booneville AR.
Right you are NDT, it is a Ben Hur G 518.Got a better pic of the data plate delivery date of 2-? 43,the camera sees better than my eyes, anyone know what kind of axle that is under it? Looks like maybe an old Ford from the bearing caps and the wheels.There was an older wheel laying in the back, Ford too?
I wouldn't call it a POS exactly if you were looking for one, it's worth more in scrap value then what I gave for it, but it will be restored as it is going to a friend of mine to put behind his CCKW, couple more pics
No EUC on this one either, paid and took it home the same day[thumbzup] also this must have Satan's trailer as the serial # is 666
