The 7 speed with Big cam engine?Any body got nsn or part number or picture of a tcm for am general 916
Yes it's a 4700sp wish I could get a stock number or part number thanks for the infoThe 7 speed with Big cam engine?
@fuzzytoaster probably has one or can flash oneYes it's a 4700sp wish I could get a stock number or part number thanks for the info
Thank you for you're helpHaving gone though these hurdles recently I can provide you everything.
ALLISON TRANSMISSION A59 TCM Control Module, 29551869 is what you need, check ebay for about $600 used. The CIN data is what you need. Simpson posted his and I can get you a pic of mine if needed. Take everything and your transmissions S/N to allison and they will program it.
Good afternoon I found a tcm and a place in Birmingham to reprogram it I can't read simpson's number can you send me you're con number thank youHaving gone though these hurdles recently I can provide you everything.
Good morning and thank you for you're help I am confused witch cin do I reprogram my tcm with yours or simpsons his is 4C0010M1007CCIN: 4F001111002A
CIN: 4F001111002A
I can't help you with that one. The only one that can tell you would be Allison by using the transmission S/N to look it up. This CIN was on my 2010 M916. My 2012 M916 is also different. There was likely updated programming as trucks were produced but this is a guestimate.Good morning and thank you for you're help I am confused witch cin do I reprogram my tcm with yours or simpsons his is 4C0010M1007C
Ok thank you very muchI can't help you with that one. The only one that can tell you would be Allison by using the transmission S/N to look it up. This CIN was on my 2010 M916. My 2012 M916 is also different. There was likely updated programming as trucks were produced but this is a guestimate.
Any chance you know the part number for the shift controller? I can pull mine out in check if you don't.Having gone though these hurdles recently I can provide you everything.
It's a wtec 4Any chance you know the part number for the shift controller? I can pull mine out in check if you don't.
