Need torque spec for fuel button cover (PT pump)
US6x4
2,188
Wenatchee, WA
I need to know the torque specs for the (4) 1/4" bolts that secure the aluminum fuel button cover / housing to the PT pump. I can't find them anywhere - does anyone know?
simp5782
Feo, Fuerte y Formal
9,339
Mason, TN
Tight as so it doesn't leak
It should be in 55-4018-1
US6x4
2,188
Wenatchee, WA
Thanks for the numbers Will. I looked through that TM Wes listed but it only mentioned torque values for some other bolts on the pump.
My problem is that it doesn't leak at idle or off-idle but it does at higher rpm while driving when I can't see it. There's actually fuel leaking everywhere since changing that button like at the cable shutoff valve on top and even on my dash oozing from the cold start primer pump...
