bob95065
- 0
- 0
- Santa Cruz, CA
I am thinking about buying a a M101A3 trailer for hauling firewood and construction materials when I need the extra capacity. I'll pull it with a 1997 Dodge Ram 4x4 diesel which should handle it no problem. I have some questions about the trailer and purchasing surplus equipment through the government:
1. Does anyone know the bolt hole pattern for the rims on the trailers? My truck will take wheels from a H2. I don't know if the military version is compatible.
2. The trailers I see for auction are all listed condition F7 which is repairable material. Can anyone let me know from experience what kind of condition I can expect to find the trailers in? I don't have a flatbed so I will pull the trailer home behind my truck. the reason I am asking is I have a 7 hour drive one-way to bring the trailer home. What materials/parts should I bring with me when I pick it up? I guess I am looking for what I should expect to do to the trailer before I start for home.
3. Are parts available for these trailers from commercial sources? Where can I get parts?
4. What is the distance from the lunette to the ground when the trailer is level? I would like to know do I get the right hitch for my truck.
5. In general how much time should I expect to pass between winning and auction and picking up the trailer?
6. Do I get to make an appointment or does the seller give a window of time for pick up? Is there a link to the pick-up procedure?
7. Is the brake on the trailer only mechanical or does it have an electrical component? I have seen trailers like this that have brakes that are disabled when the tow vehicle is put in reverse gear ( brake is disabled when the reverse lights come on). Is there a way to disable to brake when backing up?
I am a competent mechanic and am well equipped with tools. I have a compressor on my truck for filling tires and will bring plenty of tools. I appreciate your reading this post and look forward to any insights you can provide.
Thanks,
Bob Elliott
Thanks,
Bob Elliott
