New member from Washington
USAFSS-ColdWarrior
Chaplain
5,505
Welcome aboard :grin:
Find a bunk, stow your gear, and prepare to get underway :driver:
Congratz on acquiring an MV. You've called it an M318... is in really an M813???
You might want to update your user profile to be a bit more specific on your location. The website rules state this:
"• Location: We require that all members include their state in their new member profile. This allows the other members to know their neighbors. Users who refuse to add their location will be subject to warning, temporary ban, and then permanent ban. "
Not griping, just a friendly coaching to help you get settled in.
Again, WELCOME !
John
SS Chaplain
San Angelo, Texas, USA
marklwhite
Issaquah, WA
Yes, M813 5 ton.
I'm my excitement my dyslexic fingers switched the order of numbers.
We are just South of Issaquah.
Sent from my SM-N950U using Tapatalk
  • Like
Reactions: 98G
marklwhite
Issaquah, WA
I've updated my profile with my location.
The truck has been painted over but you can see US Navy markings on the doors.
It's in amazing shape mechanically!
And rust in all the expected locations.
fasttruck
622
Mesa, AZ
Along with all the welcome aboard posts here is one you can take to heart. Don't make a move without the pubs: operators' manual, organizational maintenance manual and parts book, and lubrication order. The relevant pubs are TMs 9-2320-260-10, 20, 20P, and 260 LO. There are about 40ea grease fittings on an M813, 4ea on the handbrake alone. Neglect them at your own peril. Make sure you figure out how to operate the cold weather starting aid and prime the fuel system if you are clumsy enough to run out of fuel. The TMs are available to download on this site or you could get paper copies at swap meets or on line.
srodocker
68
Lacey, Washington
Howdy howdy!!! Great group here. I may or may not have seen posts on FB of your truck stuck shortly after purchasing if it is indeed you.
Be sure to check out our PNW campout post on here and our FB PNW Steel Soldiers group as well. Glad to have another around!
marklwhite
Issaquah, WA
Indeed, that was I.
Not my most stellar moment, but nothing damaged but my ego and debit card!
Note to self: big heavy truck does not climb out of swampy ditch by itself!
I was educated that Rockwell's do not have lockers
Floridianson
2,437
Interlachen Fl.
Welcome and looks like you first lesson was a good one. Also your Rockwell's might not have lockers but some MV's do. I do not know if they would have helped you out here. Anything can get stuck so carry a push rod and check the depth to the bottom if there is one.
marklwhite
Issaquah, WA
Yeah David, only a rear winch would have helped
Nothing but scrub up front.
The F450 tow truck that showed up first tried pulling back an lifted his front wheels off the ground WITH his wheel lift on the pavement!
Then the International medium dutt tow truck showed up and both tried pulling it back and didn't budge it. All efforts were with the M813 in low range granny low spinning the wheels in the mud. All that accomplished was to sink it deeper into the mud.
Thankfully the shoulder of the road held the weight with the axles solidly aground.
cucvmule
collector of stuff
1,140
574
Crystal City Mo
I am truly impressed with you overachieving in your "first" highcenter. There is a slight learning curve when it comes to where the hard edge "is". :shock:
Good Luck to the Pair of you in sharing the mutual satisfaction of owning a Good looking Ride.:driver:
