New parking brake shoes
REO 54
Lopez Island,Washington
I need to install fresh shoes asap for my deuce P brake.My TM only show views of them but to proceedure on a change out.Previous threads don't show what I need to know.Any help out there would be greatly appreciated!
Umm..I don't know where this font came from??I just showed up!Wacky 'puters!
srodocker
68
Lacey, Washington
im sure if you bring your parts down we can see how to do it as i need to do it as well. man we need to buy that oshkosh in your picture for zombies!
gimpyrobb
dumpsterlandingfromorbit!
27,785
747
Cincy Ohio
They are mechanical, no "procedure" needed. Just take off the old ones and put on new ones. The bottom bolt and nut of the outside shoe is rather large and that makes it a pain to find a socket, but it wasn't too hard of a project over all.
srodocker
68
Lacey, Washington
you going to lewis for a recovery?!?!? what for???? i will be on lewis in the morning.
and i haven't done mine yet. mine are maxed out in adjustments right now so once that stops working im going to switch it out
REO 54
Well,got the new park brake shoes installed.Went well.Bit of a fight with that nut on the cable.Old shoes were down the rivets!Bad.
the main pins were lacking lube and starting to rust a bit.Swapped zirks,greased after install works great.That bolt is an odd size
though on the main pivot.Like 1" 3/8 was to big and 1"1/4 to small.What up wit dat??
