banditt1979
- 737
- 93
- Cincinnati, OH
Hello all, today I received, CT Blacks Trucking out of Minnesota, my first deuce which came with a matching trailer. Highly recommend CT Blacks, Cory was great to work with and guided me right off the trailer. I used a hand winch to get the M105A2 off first with Cory balancing the trailer to keep the landing gear from dropping off the back. Then slowly, in low reverse, I backed it off the trailer. Did I mention no brakes?? I had been able to get a slight pedal after filling the master cylinder with fresh DOT 5 before it shipped but nothing upon delivery. After we got the truck down I paid Cory and went to work trying to bleed the brakes. I used the typical pressure sprayer setup to bleed them, and was able to get a half pedal after pumping up, but leave it for 5-10 seconds and you have to pump them up again. Also at each wheel, it appears that the wheel cylinders were all replaced at some point, but whoever did the job used what appears to be dot 3 (amber appearance). I planned on replacing all rubber items anyway, so I limped it the mile and a half home and parked it out front. Instead of trying to fight my narrow street, I had it delivered to a large parking lot close to home with lots of room. This weekend looks like nice weather, at least Saturday, so I hope to pull it down behind my house to start working. Here are a few pics
Once I start taking things apart I'll get more pictures. Underside is pretty clean, very little rust, most of the tires are in good shape. Right front is worn bad on the outer edge so I'll have to check into that. But it has all the troop seats, two covers or tarps, 2 spare transmissions, 3 wheels with tires, 1 bare rim, and the heater assembly. Ran fine coming home, needs a fuel pump which I have a Carter to install. More to come.
