No brake Lights
ltlbo
Bunnlevel, NC
My fellow Deuce lovers: I have a 1988 M35A2 that failed state inspection because of no break lights. The rear running lights and turn signals work fine but no break lights. Can any give me a good starting point or possible ways to fix this issue? Thanks
frank8003
4,976
Ft. Lauderdale, Florida
Is yours on hydraulic side or air side?
Brake Light Air Operated Switch, M35/M54/M809/M939 etc, 11602160
Item# 11602160
$45.00
Product Description
Air operated switch for brake lights (also called a stop light switch). For many Military truck series such as M35, M54, M809, M939. Switch closes at 5-8 PSI. P/N 11602160, 7005. NSN 2540007896192. Made in USA.
I could post the TM but you already know how to find replacement instructions.
Here it is anyhow, TM + WP.
View attachment air pak stoplight switch replace.pdf
Birdsboro Pa.
Silly questions, did you have the light switch on the dash turned on?
If both lights aren't working I would start at the brake light switch as mentioned above.
If only one light isn't working then I would look at the turn signal. When you put the turn signal on, it has to turn off the brake light. Otherwise it wouldn't flash. The contacts in the turn signal are riveted to the printed circuit board. The rivets can come loose and let the contact rotate out of position. It can even contact the adjacent contact and give off some strange voltage readings.
When you put the light switch on, one of the wires at the brake light switch becomes hot. It should be 24v. The other wire goes to the turn signal switch. From the turn signal switch the power is distributed to the brake lights.
cattlerepairman
3,095
NORTH (Canada)
Not the same switch I have.....is there another version?
Yes, pics please. There are variations, some full metal, some metal and bakelite (don't like those). The shape does not matter, as long as it has the right thread. You did jumper the brake light switch wires to check that the lights themselves and, by extension, the circuit through the light switch work?
