No power!
Antonio Pena
Florida
MEP804B Generator has no power output, I’ve done a few voltage tests recommended by your forums a few months ago and had to stop. I want to start working on it again any help would be greatly appreciated
Thank You
DieselAddict
1,975
Efland, NC
Can you post a recap of what you've done so far?
Do you have the TMs and have you reviewed the troublshooting in the TM?
Antonio Pena
Florida
It’s been over three months ago I’m having problems looking up what I did, I do have the TMs all I can say is That I has checking the CR’s at start up I guess that’s where I need to start
DieselAddict
1,975
Efland, NC
I assume you've tried holding the switch in the START position after the engine starts? Do you get any voltage while you are in START?
DieselAddict
1,975
Efland, NC
Sounds like you need to start at the beginning and do some testing. Start with the MPU and speed controller. If that isn't working you'll not flash the field to make power.
DieselAddict
1,975
Efland, NC
I think more detail about what you've done to test everything would be helpful at this point.
