Not starting/ unhooked plug
Mogman
9,211
Papalote, TX
WELCOME to the SS forums!!
That is for the TPS, Throttle Position Sensor, it looks like the TPS is missing from your IP (injection pump) that will not prevent starting although it will prohibit correct transmission operation.
1987kevin
Yucaipa ca
Mine is a 2003 with the serpentine belt set up. 4 speed 4l80e. Mine requires the one with no pigtail on it, I did some reading. You have one of those available?
