NSN 2590-00-043-4241 Winch ?
SandBar
Full Time Patriot
756
231
GA/FL
Can anyone confirm the identity of a winch with NSN 2590-00-043-4241 to see if it would be compatible with a M51a2 ? Seems to be 20k capable, and has a speed reducer bolted on to make it 40k.
NDT
6,303
Camp Wood/LC, TX
i wouldn't buy that for a 5 ton. The worm shaft probably won't have the proper machining to receive the winch driveshaft.
simp5782
Feo, Fuerte y Formal
9,339
Mason, TN
Do you have the dual output PTO? Otherwise the winch won't do you any good cause you can only run the bed off the rear facing PTO
You also need frame extensions
1,807
The M51A2 uses the PTO accessory drive for the bed so a front facing PTO is present.
