Oil filters and belts... quick info please
CanonNinja
Houston, Tx
Going to be working on the truck tomorrow, replacing the belts and oil/fuel filters, and need to get the part numbers to check with local places if possible. I know I can search, but I'm out the door to drive the beast up to a friend's place to work on it tomorrow. Thanks guys.
ken
25
Houston Texas
napa #'s are
alt belt #9476 2 ea.
air compressor belt #9510
wix air filter #42837
wix primary fuel #33511
wix secondary fuel #33512 2 ea.
Oil filters are napa 1133 gold. Or fram ch33apl.
I usally by the wix filters because they come with the gaskets you need. Although other filters fit. They don't allways come with the gaskets you'll need.
The local auto parts i use keeps all the filters for multis in stock for me. You may need to go to a big truck parts house to get some stuff.
1,807
Additional note. The WIX oil filter is 51133 and the 42837 aiir filter is not designed up to the 410 CFM flow as the OE air filter element.
JDToumanian
14
Phelan, CA
Those are the new lines I got from TNJ Murray... They're cadmium plated. My old ones were rusty and the flare nut on the #2 cyl was rusted to the line so it twisted the pipe off when I removed it. I think these new ones are made in Korea. They barely fit and the tubes take a slightly different route to the injectors so I haven't figured out how to attach all the little vibration dampers yet...
My deuce is on blocks getting painted, wheel cylinder r&r, and also front axle boots and seals, so it will be another few weeks before I get to test drive it with the new filter housing.
Jon
1,128
And I assume everyone is selling the same lines, aren't they?
JDToumanian
14
Phelan, CA
I don't know... Saturn is sold out, but theirs used to be originals. I didn't shop around, but I would if I was going to do it again. NOS would definitely be better than these, but would probably cost 2-3 times as much.
I'd actually prefer to have a good used set... but these will be fine if I can get them tweaked enough to get the vibration dampers on.
vbrescueman
Dismal Swamp VA / Cochran,GA
Hey guys ...just curious my oil filters are leaking-because i replaced them and I was wondering if the napa/fram thread directly onto the stock mount--or do I have to fab up something? All help is appreciated as I am working on this as we type...
Doc
bottleworks
Central NC
vbrescueman said:
...and I was wondering if the napa/fram thread directly onto the stock mount--or do I have to fab up something?
Doc
I refer you to remote oil filters (it's what I have and uses better filters):
http://www.steelsoldiers.com/index.php?name=PNphpBB2&file=viewtopic&t=9898
Or here:
http://www.steelsoldiers.com/index.php?name=PNphpBB2&file=viewtopic&t=10321
or here:
http://www.steelsoldiers.com/index.php?name=PNphpBB2&file=viewtopic&t=6700
and here:
http://www.steelsoldiers.com/index.php?name=PNphpBB2&file=viewtopic&t=6656
PM me if you want updated pictures of the finished/updated R.O.F. project.
vbrescueman
I have read your ROF set-up...very nice [thumbzup] but a bit too $ right now. :shock: I'm just trying to get everything rolling on the truck for now which is why I was wondering about the napa's, etc. and if they mounted directly.
Thanks,
Doc
bottleworks
Central NC
The NAPA 1458 oil filter needs a replacement oil filter housing assembly or machined adaptors made to get them to spin on. There is no known spin-on filter that can "just work" with the stock setup. The oil filter housing that uses the 1458 filter is machined different to allow the filters to mate with it.
