- 34,012
- 1,807
- 113
- GA Mountains
I've had this problem with the multifuel engine that I installed in the M108. I know it has oil pressure because when we burped it while it was still in the other truck, the oil gushed out where the can was missing. I got the dash out of the donor truck and it had a 120psi gauge in it. When I got the truck running, the gauge didn't read. Figuring that the sending unit might be wrong, I installed a 60 psi gauge but still had nothing. Luckily I had and extra 120psi gauge too. I swapped that and still nothing. After a bit of searching, I found another 120 psi sending unit (years of collecting). After installing that I hooked everything up, still nothing. Last night I spoke with Cranetruck and he said the gauges need to be grounded. I had been testing gauges before installing them so there was no ground. Today after starting the truck I touched one of the mounting bolts of the gauge on one of the dash bolts and it worked! At least I know why they put the 120 psi stuff, runs a little over 60 psi at idle. I'm pretty happy considering the no oil pressure issue that brought about this engine change. Bottom line, make sure your dash panel and gauges are grounded.
