Oil Stains on CARC, how to remove?
Coffey1
493
Gray Court SC
Purple power full strength and pressure wash will clean it the best it will come tan the hardest to keep clean will that flat porous paint will hold everything. So clean and touch up paint.
zout
154
Columbus Georgia
I use a product from Flynn Distributing (has a web site) and its a green degreaser.
It takes the grease stains out of the house carpet when I screw up and too lazy to take my shoes off - does not hurt the carpet or discolors it - it eats grease and oil.
I have a white baseball cap and after spraying that down when it is full of grease stains its perfectly white again - use it on my cloths as well before washing.
We use it at the shop for getting grease and oil stains out of the white trucks finish - does not hurt clear coat or paint and removes the stains even.
Its what I used to wash PB's engine with after doing the body work.
He will ship it and it comes in spray quart bottles.
1,168
Cover the clean areas with oil to match.
Or, when I blew a hydraulic hose on the M819 I used hot water and Dawn dish soap with a brush. It did pretty well.
KansasBobcat
San Antonio, TX
A difficult problem. The older the CARC, the harder it is to clean. A perfect hand print on side of 998 in the 383 green. I tried Dawn, acetone, lacquer thinner, simple green and nothing worked completely..Was going to repaint anyway but tried RAPCO 383 without priming for touchup. The print could still be seen! However, after priming and then painting it was covered but of course did not match the old adjacent CARC very well. I've learned to be careful where I touch, especially with oily gloves!
98G
Former SSG
3,986
Hot water running gently over it. Takes a while, and wastes both water and the power used to heat it....
Oil is lighter than water so will float up and the water will carry it away. The heat from the hot water decreases oil's viscosity and helps this along.
Works best on horizontal surfaces. I've got oil stains out of concrete driveways this way, as well as the bed of cargo trucks.
