Possible wiper switch issue
jeepjseries
Fort Sill
Wipers and pump on my 1984 M1009 didn't work when I got it. I checked the motor and fuse. It appears to work when I hooked 12 volts to it. I'm thinking it's the wiper switch any ideas?
cpf240
Free in Northern Idaho
Did you try bypassing the filter capacitor tree next to the wiper motor? You can plug the connector directly into the wiper motor and remove the capacitors from the circuit, they are only there for noise suppression.
jeepjseries
Fort Sill
Screw it I decided just to run a universal wiper switch. I don't wanna order/ pay 100 plus bucks for one just to figure out that's not the problem.
cucvrus
9,603
Jonestown Pennsylvania
HA HA. I see others have fought the wiper switch issue and decided to not attempt the change. This is like a bad apple. Now the plow M1009 at work has wiper issues. I see things happening in series and droves on these trucks. Maybe the wiper switches have reached the maximum life expectancy. On the work truck it seems to be the plug that runs to the wiper motor from the main harness. I guess I will sacrifice a wiring harness and cut that plug out. Only works when you push in and up on the plug. Several wiper motors and same thing. Visually I see nothing in the plug. Who knows. It has lived past its intended life and is surviving year to year at this point. I got here looking if others had the same issue. Be Safe and Stay Warm. Bad Weather coming to my area this weekend.
cucvrus
9,603
Update. I cut the wiper plugs from a donor CUCV wiring harness and replaced the big plug going into the wiper motor on the M1009 plow truck. That was the winning combination. Not sure what was shorted in the molded plug but it was the problem. I replaced the wiper motor again this year and could not see or find anything wrong with the plug. Electrical items and connections are a weak area for me and I don't pretend to know it all about it. Somethings I just slept thru class on and never cared to catch up. I know about enough to keep me going in the right direction and avoid trouble. Many times it takes me longer but I get it figured out. Asking friends and checking a known operational vehicle with a test light is about as far as I go. I have a nice Fluke meter and use the voltage and ohms. That's about it. Have a Great Weekend. I was all ready to do the wiper switch.
