Power Switch does a 360
fuzzytoaster
3,037
Fort Worth, Texas
The power switch on my, soon to be, deuce does a complete 360 degree spin. Has this happened to anyone else? Any fix for it?
davidkroberts
23
west tennessee
to be clear is it the handle of the switch or the switch itself that is turning? is the entire switch assembly rotating in the hole in the dash until the wiring behind it stops it, or is the part you turn that rotating on the shaft of the switch but the switch is securely mounted?
Either way, you probably need another switch, this might be a good time to get a keyed ignition switch. I think beechwood canvas had some. Beats having to chain the wheel and remove the batteries to keep joyriders away.
fuzzytoaster
3,037
Fort Worth, Texas
By what I was told it was the actual lever not the whole switch. I'll look into it.
davidkroberts
23
west tennessee
if the lever is the only thing going around you might be able to just push it in and use it normally, my M715 has done that since ive owned it. never got around to fixing it. I figured between that and the floor starter which one like 1 in 30 people would even recognize it keeps the wife from hiding it when im deployed....lol
