pre bent supply pump rubber hose?
121
Metairie, LA
The rubber hose attaching to the fuel supply pump on my m1009 appears to be pre bent (and leaking) . I cant find a part # in the 20tm. I saw a thread where someone had just used standard hose, I do worrry about collapse under vaccum however. I need to replace mine asap. Anyone know a part# or have any suggestions for an alternate? Looks to be 3/8 pre bent fuel line.
Efituned
Midland, Ga
I called many part stores and dealers trying to get that hose and no one had it. I went to my local hydraulic supply store and bought their strongest hose so that it wouldn't kink. I originally tried a regular fuel hose and it seemed to kink real bad and collapse under suction. I also cut the u-turn out of the hard line so basically the fuel hose was making a big u-turn into the fuel pump.
GreenBull
SE Michigan
A spring inside the hose is something done in a lot of original equipment applications such as this. Find a loose wound spring of the right size and put in the non molded hose.
tbearatkin
24
SouthWestTennessee
This looks like could be it but would have suggest looking at the old one and see if it matches. Not the same part number I found for it (TM 34P has a PN 14063301)
HOSE. Fuel Line. Fits: Chevrolet: P30 VAN (1985-1993), P20 VAN (1985-1990); GMC: P35/P3500 VAN (1985-1990), P25/P2500 VAN (1985-1990) (14042368)
Here is the whole fuel system look by the fuel pump in the drawing and see if that hose shape matches.
GP FUEL SUPPLY SYSTEM/DIESEL; G FUEL INJECTION SYSTEM (LH6/6.2C,LL4/6.2J) DIESEL; P3 FUEL INJECTION SYSTEM (LL4/6.2J) DIESEL;. Fits: P20 VAN, P25/P2500 VAN, P30 VAN, P35/P3500 VAN | Nalley Buick GMC Brunswick
Asmoday
Los Angeles, CA
I used Gates 3/8" Fuel injection hose which is stiffer walled. I made sure it was a viable loop so it would not kink and have had no issues.
