pressure washing paint off
peecook
Richmond VA
tried sand blasting on the M109, went through 10 bags and barely made a dent. was told a pressure washer with 4000 psi and a 45 degree tip would take it right off. just wanted to see if anyone else had any luck with this process or any other suggestions.
El_Guapo
Sandy Springs, GA
The only way a pressure washer will eat steel is with sand injection and 20,000+ psi. It can break glass at almost any pressure. On a safety note being cut by high pressure water is an injection wound not a regular cut. It has to be cleaned and irrigated like a needle stab.
  • Like
Reactions: NDT
Capt.Marion
15
Atlanta, GA
Re: RE: pressure washing paint off
That's a pretty important detail to note. I guess I can't skimp off on my monthly shower that way...
Keith_J
1,313
Schertz TX
It is going to take more than just 4000 PSI and a point nozzle to pull paint off of mine. Works slowly on weathered CARC.
Might take me 100 gallons of gasoline to do the entire truck. I'm going to try the sand attachment.
